Author: Subject: Longer Wheel Studs
The Doc
posted on 22/9/07 at 01:41 PM Reply With Quote
Longer Wheel Studs
I need 8 longer than standard wheel studs to accommodate my alli wheels.
Can anyone help or suggest a common application for this (that I can find at breakers) as I don't really want to shell out 20 odd quid for a set on ebay!
TA
Mike
The Doc
posted on 22/9/07 at 01:42 PM Reply With Quote
by the way Cortina hubs
Duncan_P
posted on 22/9/07 at 02:49 PM Reply With Quote
Rally Design do various longer studs for Fords (presume the do 'tina ones)
From memory they are sub £1 each which isn't massively extortionate
robinj66
posted on 22/9/07 at 03:33 PM Reply With Quote
Midland Wheels had a box of them @ Donnington
Paul TigerB6
posted on 22/9/07 at 05:49 PM Reply With Quote
Would you really want to use a set of 2nd hand wheel studs that had been battered out of an old hub?? Pretty safety critical item really.
Would also be an awful lot of work for the sake of saving £15 or so.
Might be worth trying a local alloy wheel specialist first off anyway.
