Author: Subject: brake servo/master cylinder
welshboy
posted on 22/9/07 at 02:21 PM Reply With Quote
hi all help please ! could any one tell me if its ok to have the servo/ beake master cylinder lower than the front calipers im having trobule to get the servo and stearing collom in thanks
repper
posted on 22/9/07 at 02:38 PM Reply With Quote
hi mate as far as iam a wear as long as the brake fluid reservoir's are mounted high for the air to escape you should be ok
caber
posted on 22/9/07 at 03:51 PM Reply With Quote
I heard a lot of moaning here about getting a good pedal on a 7 build so I went for top hung pedals using Sierra bits with the master cylinder above the top rail of the chassis. from there I ran all brake pipes downward to calipers and the back axle. I am pleaqsed to report that this set up blead through by gravity in 5 mins and took about 2 strokes of the pedal at each bleed nipple to get a rock solid pedal, that's the fastest and easiest brake bleeding exercise I have ever done! So get gravity on your side and you will be OK.
Caber
posted on 22/9/07 at 04:01 PM Reply With Quote
Do you really need the servo?
Mark Allanson
posted on 22/9/07 at 04:45 PM Reply With Quote
No, you will lose all feeling in the brakes
welshboy
posted on 22/9/07 at 06:30 PM Reply With Quote
do you think id be better off with out a servo ?im running a 1300 crossflow and thanks for the replys so far
JAG
posted on 22/9/07 at 07:33 PM Reply With Quote
I've got a servo and it's mounted lower than the front calipers, although only just lower.
You won't loose any feel.
I'm also a professional engineer who designs brake systems for a living
Justin
niceperson709
posted on 22/9/07 at 08:55 PM Reply With Quote
Just want to suport what Jag is saying about servos . I have one on my car and it works fine and as I have a some what shorter peddle with less leverage than the original , still the effort required and the feel are both good.
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
posted on 23/9/07 at 03:28 PM Reply With Quote
Speaking personally a servo is the last thing i would want it robs the pedal of all feel and introduces unwanted pedal travel and spongeyness, but drivers of modern cars are so used to grossly over servoed brakes that they would find the brakes on most Seven replicas take a lot of getting used to.
Seven type car although very light because of space restrictions is a bit short on pedal leverage ratio so the pedal riquires a good bit more effort pedal than the average tin-top.
[Edited on 23/9/07 by britishtrident]
