Alex B
| posted on 15/10/07 at 10:27 AM |
Brake M/c
Have plumbed in an Escort M/c which has 3 valves .........1 to the back and two for front. This will now need replacing and it is discontinued. I was
thinking of an old model Sierra bought new as being the least problem to plumb in.
I have also seen some new old stockToyota stuff with two valves. Is this acceptable for SVA?
Alex
UncleFista
| posted on 15/10/07 at 01:55 PM |
Would
this be of any use ?
Tony Bond / UncleFista
Alex B
| posted on 15/10/07 at 04:50 PM |
Thanks for link Tony. He is milking it at that price..............I`m trying to build a car for £249 and going by how it looks I`m succeeding
Alex
robinj66
| posted on 15/10/07 at 05:41 PM |
Looks similar to master cylinder from capri/Cortina if that helps
skidude88
| posted on 15/10/07 at 06:13 PM |
Sorry to jack this post (Was just about to put a post up and found this thread)
I'm tryna ID what my Cylinder is/would have been originally off (didn't build the car)
The part number on the side is 64676774, which is different to the one on ebay, but I'd say looking at the picture its the same unit.
Reason I'm tryna identify it is I'd like to see if there's any way of fitting a remote reservoir.
The middle (top view) picture below, shows its a little close to the steering.
When on the anchors, parking up, the slight flex in the bulkhead means that I can feel the steering catch the reservoir and I think I'm getting
a leak on the seal.
Any help appreciated
  Original Master cylinder
  Original reservoir top & Steering column
  Original brake reservoir
Early MK de-Dion CBR1000 FJ-FP.
Alex B
| posted on 15/10/07 at 06:24 PM |
No probs mate ............I love looking at M/Cs.........It`s a passion since this one farked up Right I`ve heard about your illness I want to talk
about my illnesss now which is worse Yours may be the original cast iron one ? Is the two valve one ok then guys? The one on mine was
ATE.....discontinued.
Alex
[Edited on 15/10/07 by Alex B]
UncleFista
| posted on 15/10/07 at 07:58 PM |
TBH mate, I'm in the same boat as you, looking for a 3 outlet M/C.
Ours is farked, and since I've re-sealed it, it's worse No-one recognises it, so I've come to the conclusion it must be pretty
rare (it's from such a rarity as a 1.3l 1978 Ford Escort).
I've bought a new M/C from ebay, but it's not the right one, I'm thinking of using a 2 outlet one and connecting a "T"
piece.
Can anyone see any problem with that ?
Wanna buy a master cylinder that looks like a standard Escort M/C but turns out to be totally the wrong type ? Cheap....
Alex B
| posted on 15/10/07 at 08:47 PM |
What about early 1.6 sierra anyone used it ? does it have 3 valve any pics. I`m thinking about 40 quid. Someone mentioned LR 90 Def one . No Britpart
please.
Alex
