prelude1980
| posted on 21/10/07 at 06:05 PM |
Polybushes to Rose Joints
I've just finished building my Avon and noticed going to full lock i get my top wishbone slide up and down on the steel tube in the poly
bush.
if i re did the wishbone to change to rose joints would this cause any major problems, i have read about increase in vibration/bumps?
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
| posted on 21/10/07 at 06:12 PM |
Wishbone bush sizes and crush tubes lengths aren't set up properly
prelude1980
| posted on 21/10/07 at 06:29 PM |
yeah i can see that they are wrong, Typical Tiger thing i think,.
i was wondering if i converted to rose joints would this cause problems?
just i can get more adjustment from rose joints.
gets you.
Avoneer
| posted on 21/10/07 at 07:14 PM |
Is the crush tube tight between the bracket sides?
If so, use a washer with a hole bigger then the crush tube to hold the poly bush tight in there as well.
Pat...
RazMan
| posted on 21/10/07 at 09:58 PM |
I would stick with the poly bushes if you can - rose joints that will handle the punishment of a wishbone are around £25 each. Any cheaper than this
and they will quickly fail.
Also poly bushes insulate you from a surprising amount of road noise.
Raz
prelude1980
| posted on 22/10/07 at 05:49 PM |
thanks Razman, thats answered my question of other problems from having rose joints, althou i have about 16 fairly expensive joints that probably
wouldn't break but noise cost be a problem
gets you.
| posted on 23/10/07 at 08:43 AM |
Pat...
Better to trim the crush tube down to the correct length and pack out with penny washers with the same sized hole as the inside of the crush tube
(i.e. one suitable for the bolt being used).
If you use washers that go over the crush tube you risk them turning as the suspension moves and eating into the brackets.
[Edited on 23/10/07 by MikeRJ]
prelude1980
| posted on 23/10/07 at 04:59 PM |
thanks Mike i'll go with your suggestion makes sense
gets you.
