smart51
| posted on 24/10/07 at 07:55 PM |
tyres - what to do.
I have a set of Toyo T1-S on my car that I don't really like. 3 are part worn buy have life in them yet. the other is the same but the
outside 20mm have very little tread after a day at curborough.
I have a spare Pirelli P6000 which is in good nick and is a tyre I rate higher than the T1-S.
Do I:
1) Put the P6000 on for the £5 it will cost to have it balanced. After all, it won't be too long until It needs a complete new set.
2) Buy a new T1-S for the length of time it takes for the others to finally wear out then replace them all.
[Edited on 24-10-2007 by smart51]
speedyxjs
| posted on 24/10/07 at 08:01 PM |
I would suggest 1
Guinness
| posted on 24/10/07 at 08:04 PM |
Easy one this, it's a 3 step programme:-
1. Rotate the tyres,
2. Do another track day,
3. Repeat until all tyres are bald!
Get a set of R888's!
Mike
jos
| posted on 24/10/07 at 08:06 PM |
If you dont like the tyres then change em sooner rather than later and try to flog on the t1s'
Youll enjoy the driving a lot more
Coose
| posted on 24/10/07 at 08:08 PM |
As Guinness said, 888s every time! I really wouldn't compromise on the most important part of the car with regard to making the thing stick!
Spin 'er off Well...
Danozeman
| posted on 24/10/07 at 08:28 PM |
I'd either go for number 1 or sell the lot and get some tyres u want.
Dan
smart51
| posted on 24/10/07 at 08:30 PM |
I've just looked on the web and it says that you only need 1.6mm across the centre 75% of the tyre. The wear is on the outer 20% so I'm
fine for the time being. Thanks for all your advice.
repper
| posted on 24/10/07 at 09:05 PM |
i'd go for the spare Pirelli P6000 super tyre
good all round grip and if your not side ways all the time thay seem to last as well
Avoneer
| posted on 24/10/07 at 11:22 PM |
Number 1.
Wear them out and the put some 888's on.
Or Yoko A048's which are much better than 888's.
Pat...
