bob tatt
| posted on 24/11/07 at 11:33 AM |
rear calipers
just a quick one as its not explained very well in the haynes manual should the two studs that the caliper fits onto be free as in removable from the
caliper carrier or as mine are one of the studs on both carriers appears to be either seixed or designed that way just want to clear this up before i
break it trying to free something that is not designed to be free cheers
Danozeman
| posted on 24/11/07 at 11:37 AM |
Sierra calipers??
If your talking about the slide bolts that hold the caliper onto the carrier they should unscrew from the carrier and slide in and out of the caliper.
Dan
bob tatt
| posted on 24/11/07 at 12:32 PM |
cheers was just a little unsure about this one got a seized one on both carriers any tips for freeing them up with out damage would be good already
wd40 them still no movement
chris_harris_
| posted on 24/11/07 at 12:38 PM |
Heat heat and more heat, making sure theres no brake fluid in them first. You'll need a full overhaul kit afterwards too, the seals will all
melt..
Regards Chris
jollygreengiant
| posted on 24/11/07 at 01:06 PM |
Remove caliper(s) from carrier(s) [13mm bolt spanner size and 15mm (irrc) for the slide pin].
Remove rubber dust covers (new ones quite often come with recon calipers).
Use electrolitic/electrolosis bath on carriers.
Remove from bath remove pins, clean & repaint as neccessary. Reassemble/refit as required.
bob tatt
| posted on 24/11/07 at 04:19 PM |
what the hell are these and where would i find one.
jollygreengiant
| posted on 27/11/07 at 09:15 PM |
Front page of locostbuilders. Most viewed threads. First entry and read ALL the way through. One of the most usefull and cheapest tools we could use.
