Mr Whippy
| posted on 26/11/07 at 04:26 PM |
oval wish bone steel
hi
has anyone found a supplier of oval section metal rather than round tube for making wishbones as I have some to make now and these are biggies.
ta
D Beddows
| posted on 26/11/07 at 04:41 PM |
Ralt
worX
| posted on 26/11/07 at 05:02 PM |
You could also U2U Nitram38, I think he's made his 'bones using an elliptical shape...
caber
| posted on 26/11/07 at 08:42 PM |
tons parked outside your local supermarket
round tube and a long press bed, make sure the weld on the tube is at the bottom before you press it
mine came as offcuts from a rather grander project that is now sadly RIP
Caber
Triton
| posted on 26/11/07 at 09:19 PM |
Try any steel stock holder and ask for flat oval tubing..or ikea as they seem to use it for 'puta desks
procomp
| posted on 27/11/07 at 07:59 AM |
Hi if it's the STD stuff that most manufacturers use it's technical name is flat sided oval commonly referred to as furniture tubing
However if you are after the proper stuff go direct to SPA as they supplie most of it to the others.
Cheers Matt
[Edited on 28/11/07 by procomp]
Mr Whippy
| posted on 27/11/07 at 07:51 PM |
thanks guys I'll see how much the want for it.
Mark Allanson
| posted on 27/11/07 at 08:08 PM |
Ask an engineering firm to throw some round seamless through the rollers
flak monkey
| posted on 29/11/07 at 07:41 AM |
D Beddows has it right.
Ralt sell the proper CDS oval tubing for between £6 and £8 per metre. A fraction of the price that Spa want. They also sell spherical bearing housings
to weld into the ends of the tubes to save you some time.
Ralt Catalogue
Sera
http://www.motosera.com
