Rallye_Mark
posted on 17/12/07 at 08:39 PM |
Will Sierra Front Calipers fit under 13inch Comp ML's?
I have just bought some Compomotive 1380 alloy wheels and I have Sierra front hubs, I am just wondering if I bought some standard Sierra calipers if
they would fit under these wheels and what discs should be run?
Are there any other alternative brake calipers that will fit the sierra hubs?
Cheers Mark
bonzoronnie
| posted on 17/12/07 at 08:49 PM |
Sierra calipers
I believe the early Sierra was originally fitted with 13" wheels.
Someone will correct me if I am wrong.
If you rim offset is correct, i see no reason why you cant run with the original Sierra discs & calipers.
Ronnie
smart51
| posted on 17/12/07 at 08:51 PM |
but with drum brakes.
TimC
| posted on 17/12/07 at 08:54 PM |
Not on the front they didn't. I'm not familiar with the MLs, but I think you'll be fine. The rear end will be more of a worry.
The only wheels that I am sure fit over Sierra handbrake calipers are Compomotove CXRs and Caterham's multi-spoke rims.
mookaloid
Drums at the front????
bonzoronnie
posted on 17/12/07 at 09:00 PM |
Drum Brakes
The last time I saw drum brakes on the front of a car, Circa 1960's I think
Ronnie
smart51
OK, OK, I was thinking of the rears which are the big problem. It is the handbrake lever that fouls 13" rims. The front brakes don't
have a handbrake lever.
snapper
| posted on 17/12/07 at 09:09 PM |
The 13 inch donor wheels fitted over my drum rear, disc front set up but i did need some thin 5mm spacers on the front, now running 14"
I eat to survive
I drink to forget
2b_pablo
| posted on 17/12/07 at 09:13 PM |
Ive 13s on the back of mine with sierra calipers and discs.
the handbrake mechanism needed a little hammertime action to stop it fouling tho.
not sure how Im going to get wheel weights on tho!
Gazza
| posted on 18/12/07 at 01:05 PM |
I've got Sierra front uprights with vented discs and rear 9" drums - all fit inside my 6x13 Superlights - bit tight but don't hit
anywhere or catch on anything.....
Just a bag o' rusty spanners
Rallye_Mark
| posted on 23/1/08 at 09:47 PM |
So will any Sierra caliper fit on the front not including the 4x4's or cosworth models?
For anyone with 13 inch wheels, what disc size is it that is used and what calipers are you using?
Cheers again, Mark
bigrich
| posted on 23/1/08 at 10:40 PM |
260mm solid discs and wilwood calipers on the front of mine under 13 inch cxr's
