Author: Subject: Using the correct grade steel
Dave Bailey
posted on 18/12/07 at 09:58 PM Reply With Quote
I have one of the rally design splined steering shafts and need to cut an extend it. What steel tube should I use to do this. Wall thickness and steel grade?
Also need to make some engine mounts and I would like to make them tubular so again what material should I use?
thanks
Dave b
Mr Whippy
posted on 19/12/07 at 08:33 AM Reply With Quote
steering - 4-5mm thick
mounts - 2in tube 2mm thick
grade - should rust, not that important so long as it's thick enough
you can tell by the long gap before anyone answered this that no one has the faintest idea of the grade their using, 'but I just found it in the scrap skip!'.
[Edited on 19/12/07 by Mr Whippy]
bonzoronnie
posted on 19/12/07 at 10:19 AM Reply With Quote
Steel grades
You forgot to mention if the tube should be seamless or ERW
Seamless tube would be the strongest. Any grade seamless should do. Cold drawn that is. !!??
It,s nice to know we have at least one person on the forum that has a working knowledge of steel.
Ronnie
[Edited on 19/12/07 by bonzoronnie]
Mr Whippy
posted on 19/12/07 at 11:02 AM Reply With Quote
me I'll just use any old crap so long as it's cheap
cardboard now that's a building material
posted on 19/12/07 at 01:33 PM Reply With Quote
MILD STEEL eg. plain oridinary low carbon general purpose structural steel.
Use anything else and you could end up with failed welds.
If you weld higher strength steels you would need to heat treat the part --- no big deal for a small part.
[Edited on 19/12/07 by britishtrident]
speedyxjs
posted on 19/12/07 at 01:54 PM Reply With Quote
Isnt that the idea behind the £250?
