LBMEFM
| posted on 22/12/07 at 08:33 AM |
Gear Change
It is coming to the point soon on my MK Indy - Fireblade build to decide whether to go for Paddle Change or Gear Stick. Drove a gear stick sequential
box felt great but the paddle change looks good.
So please help me make up my mind with your experiences.
Which system should I use?
Phil.J
| posted on 22/12/07 at 09:49 AM |
I'd go for a stick every time. Less hassle, simpler to install, faster, more positive feel. Just use a cable with small rod ends and not a
mechanical linkage, and arrange for the knob to be immediately adjacent to the rim of the wheel (within an inch).
zxrlocost
| posted on 22/12/07 at 10:39 AM |
paddle shift every time you only have to watch the BEC vids
oh and you can keep both hands on the wheel
the linkage is exactly the same as the other gear linkages cable or rod and pivot
Wadders
| posted on 22/12/07 at 11:06 AM |
Iv'e had both and would say the paddle has the edge in terms of useability especially if coupled with a trickshifter which cuts the engine when
changing up, mine also has autoblip on downchanges which is a godsend when hard braking.
Whichever system you decide on, try to have as few joints in it as possible with no play in them. The ST supplied stick linkage i had felt quite
sloppy, although in practise it worked reasonably well.
Al.
[Edited on 22/12/07 by Wadders]
desyboy
| posted on 22/12/07 at 11:31 AM |
Paddle shift anyday.
MikeR
| posted on 22/12/07 at 12:21 PM |
why not both?
kev R1
| posted on 22/12/07 at 12:26 PM |
i'd go for a paddle change rod system, wouldn't bother with cables there not a great feel!
tks
| posted on 22/12/07 at 03:02 PM |
Al.
How does the auto blib work??
How does the system knows when you push clutch???
Tks
