Author: Subject: replace bolts
bracey
posted on 8/1/08 at 03:57 PM Reply With Quote
replace bolts
upon changing the rear diff (sierra with bolt on shafts) should i replace the driveshaft bolts??
cheers
richard
pewe
posted on 8/1/08 at 04:08 PM Reply With Quote
As long as they are the correct diameter for the holes & aren't chafed my inclination would be to replace the nuts only (assuming they are self-locking). Bolts should be 8.8 or higher so shouldn't stress fracture.
No doubt someone else will confirm or otherwise.
Cheers, Pewe
jacko
posted on 8/1/08 at 04:49 PM Reply With Quote
Yes i would and did.
I think thay are 50mmx8mm the bolts i used have the end for allan keys cant think of the proper name for them
it's bean a long day
Jacko
iank
posted on 8/1/08 at 04:53 PM Reply With Quote
Jacko
Cap head?
Anonymous
jacko
posted on 8/1/08 at 05:01 PM Reply With Quote
Thankyou
twybrow
posted on 8/1/08 at 05:11 PM Reply With Quote
Cap head usually means higher grade - is it 12.9?
posted on 8/1/08 at 05:31 PM Reply With Quote
Cap heads are usually 10.9 or 12.9 where I get bolts from.
iank
posted on 8/1/08 at 06:08 PM Reply With Quote
Yes, only IKEA seem to use allen screws made from cheese.
[Edited on 8/1/08 by iank]
Anonymous
bracey
posted on 8/1/08 at 06:39 PM Reply With Quote
the ones on allready are torx ?does it make a diff erence parden the pun as to what end they are?
jacko
posted on 8/1/08 at 07:16 PM Reply With Quote
The bolts that are torx are the original ford bolts
