Author: Subject: Which Handbrake Cable?
beppesignori
Contributor
Posts 82
Registered 7/8/06
Member Is Offline
Photo Archive Go!
Building: MK Indy Sold. Contemplating V8 midi scratch build
posted on 12/1/08 at 07:48 PM Reply With Quote
I am building an Indy, and using Sierra Cossie solid discs in the back, and the standard lever. Is there a special cable for that, or are all sierra cables the same? Where can I get the cable I need?
Would these do, and is the price about right?
http://cgi.ebay.co.uk/Ford-Sierra-Saphire-Brake-Cable-Handbrake-1984-1993_W0QQitemZ220188133167QQihZ012QQcategoryZ21654QQcmdZViewItem
[Edited on 12/1/08 by beppesignori]
mackei23b
posted on 12/1/08 at 08:55 PM Reply With Quote
Hi there
I've got the same set up, got mine from MK.
Ian
RazMan
posted on 12/1/08 at 09:02 PM Reply With Quote
Fairly sure that cable will be ok but you will probably have to shorten it and fit a new nipple thingy.
Raz
posted on 13/1/08 at 12:15 AM Reply With Quote
Price looks about right.
Usually the adjuster is on the shorter outer cable. I ended up getting two cables cutting them in half and using the two shorter (adjustable) outers with two inners joined with wire clamps...
