Aico
| posted on 18/1/08 at 09:31 PM |
LSD/Torsen ID
I'm looking for a Striker at the moment. It's got a live rear axle. How can you identify what diff is inside? I know you can lift the rear
and spin a tire and see what the other one does. This to check if it's an open diff or a LSD. But how do you check for a Quaife diff? It has a
preload right? So both wheels should spin the same way so how can you identify if it has a clutch-type diff or a Quaife/Torsen?
Can someone with a Quaife diff do this test to see if both wheels turn the same way?
madteg
| posted on 18/1/08 at 09:40 PM |
lsd
Just because both wheels spin the same way does not mean it is lsd, I got court out like this.
Aico
| posted on 18/1/08 at 10:25 PM |
With an open diff the wheels spin the opposite way. This is a fact. How can you state this is false?
mark chandler
| posted on 18/1/08 at 10:48 PM |
Knacked planet gears, both spin the same way, thats how.
Aico
| posted on 18/1/08 at 11:18 PM |
Yea if it's broken LOL Anyway back to topic. Is there some way to check if it's a LSD or Quife from the outside?
foes
| posted on 19/1/08 at 12:12 PM |
Yep, i've got a live axle with quaife atb and the wheels both turn in the same direction.
cheers
