Author: Subject: Pitting Chrome
speedyxjs
posted on 24/1/08 at 09:41 AM Reply With Quote
Pitting Chrome
Im looking at some chrome wire wheels on the bay of E but the seller says they are chrome. The wheels are going cheap (at the mo) and i thing a sevenesque car would look quite good with wires. Whats the solution to pitting chrome? Will i need to get them reconed?
Phil.J
posted on 24/1/08 at 09:46 AM Reply With Quote
Old wire wheels can be a PITA, the main problem being the spoke adjusting ferrals corroding and seizing.
Plan on having the spokes cut out, rechroming the rims and hubs and replacing the spokes with stainless ones.
It won't be a cheap option!
thunderace
posted on 24/1/08 at 09:52 AM Reply With Quote
it would be cheaper to buy new wheels than get them redone as it needs striped with cyanide and polished and most platers wont be intrested in it as its a bugger.
i was an electro plater for years zink copper brass silver nickel chrome gold ,and i done anodizing and powder coating ,bugger that was years ago before i got my kit car....
thunderace
posted on 24/1/08 at 10:01 AM Reply With Quote
look at this
http://cgi.ebay.co.uk/gold-chrome-wire-wheels-13-14-15-16-17-24_W0QQitemZ120211333989QQihZ002QQcategoryZ28648QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
mcerd1
posted on 24/1/08 at 10:13 AM Reply With Quote
Originally posted by thunderace
....,and i done anodizing and powder coating ,bugger that was years ago before i got my kit car....
thunderace - on an almost completely unrelated subject - you wouldn't happen to know anywhere north of the border that does anodizing would you?
I've got a few custom made alloy bits that could do with it.
[sorry for the hijack speedyxjs]
posted on 24/1/08 at 10:38 AM Reply With Quote
depends o how bad the pitting is; if you cannot live with that, then as ^^^ says, chrome needs to be removed and redone; unless you pay ££££ it is unlikley that the rechromed items will end up looking as good as new ones.
or paint them silver
onzarob
posted on 24/1/08 at 10:48 AM Reply With Quote
Like this
Personally I wouldn't have wire wheels on anything after having them on my Midget, a right PITA to clean, keep, tight etc. you need the center hubs as well so can be expensive.
posted on 24/1/08 at 01:11 PM Reply With Quote
Wire wheels are bad news keep clear.
Apart from everything already mentioned they are heavy.
Also the bolt on ones just look daft.
paulf
posted on 24/1/08 at 01:14 PM Reply With Quote
I had them on an MGB and wouldnt consider them for a seven for the above resons .I had lots of broken spokes and found the splines also wore causing them to clunk taking up the drive , they are also very heavy compared to most other options.
Paul.
[Edited on 24/1/08 by paulf]
Confused but excited.
posted on 24/1/08 at 05:54 PM Reply With Quote
Locost........get them powder coated?
goodguydrew
posted on 24/1/08 at 08:41 PM Reply With Quote
I am planning to use them.
I love the look of the Lotus 7 S1 with skinny wires and alloy body work.
Any one got some spare 15" wires in the shed?
speedyxjs
posted on 25/1/08 at 01:09 PM Reply With Quote
These are about 7 inches wide
