Author: Subject: sierra lobro half shaft circlips- help needed
eddbaz
posted on 2/2/08 at 09:30 PM Reply With Quote
I'm having real trouble getting hold of some replacement circlips for a ford sierra cosworth lobro bolt on half shaft , I tried my local ford dealer they found the part and part number on their system but I was told that ford no longer stock this part I also need a couple of the torqx bolts and was told the same.
Can anybody tell me where I can get hold of these items.
Many thanks Ed.
stuart_g
posted on 2/2/08 at 09:53 PM Reply With Quote
Try these http://www.sierra-diff.co.uk/ they may be able to help.
[Edited on 2/2/08 by stuart_g]
NS Dev
posted on 2/2/08 at 10:16 PM Reply With Quote
4x4 or 2wd cossie shafts??
I have some 4x4 circlips u can have
mcerd1
posted on 3/2/08 at 11:01 AM Reply With Quote
I've got some used ones off my granada (same as XR4x4 - mabe the same as cossie 4x4)
as for the bolts you can get 12.9 grade socket capheads instead (allan key instead of torx) just check the tread lengths - a full set of 24 sould only cost a couple of quid
