Author: Subject: before i Bid on some hubs!
Johneturbo
posted on 3/2/08 at 04:23 PM Reply With Quote
Hey all,
before i bid on some hubs i'm after, i need to check they will be ok.
they are Mk1 escort 1300e, and the ad says 8.5" disc brakes, they are for my mnr cortina uprights.
my question is will i be limited with what size disc brakes i can run!? as i was going to fit some wilwood powerlite calipers.
cheers
john
RichieW
posted on 3/2/08 at 04:33 PM Reply With Quote
I dont think escort hubs are compatible with cortina uprights even if they use the same braking components. The bearings are different.
[Edited on 3/2/08 by RichieW]
24vseven
posted on 3/2/08 at 06:08 PM Reply With Quote
i am pretty sure they dont fit diffrent bearing size
i will check on tusday i may have some if your not sorted by then
Johneturbo
posted on 3/2/08 at 06:10 PM Reply With Quote
Mnr cortina uprights use escort stub axels
it caught me out when i tried to fit my cortina hubs to them. like you say the spacing is different
so would these be ok then, as i've seen another set that say 9 1/2" disc brakes.
so i'm a bit confused!
RichieW
posted on 3/2/08 at 06:55 PM Reply With Quote
have a look on www.brakeparts.co.uk it shows pics dimensions for mark one and mark 2 escort discs.I think you will be ok.
As long as the mounting surfaces are the same it wont matter how big the actual disc is.
posted on 3/2/08 at 07:02 PM Reply With Quote
The problem is not whether the Ecort disk will mount to the Cortina hub, but whether the entire Escort hub will fit a Cortina stub axle.
24vseven
posted on 3/2/08 at 07:12 PM Reply With Quote
as above and as i mentioned before i am 99.99% certian the bearings are diffrent sizes i work with m1 and 2 escorts all week i will check for definate on tuseday ( day off on mon)
Johneturbo
posted on 3/2/08 at 07:15 PM Reply With Quote
thanks for the link Richie,
and the offer 24vseven
Mike, the mnr cortina uprights use escort stub axels.
Johneturbo
posted on 3/2/08 at 07:23 PM Reply With Quote
Guy my question was, can i fit bigger disc to these hubs, they state 8 1/2 discs
i know escort hubs won't fit cortina uprights with cortina stub axel
BUT my MNR cortina uprights HAVE escort stub axels
