tegwin
| posted on 6/2/08 at 03:15 PM |
Linking solid rear axle to bike engine
If you have a solid escort type rear axle and a bike engine, can you use a single long propshaft from the axle to the engine or do I need two short
props linked together with a bearing block?
I guess I need a telescopic prop to acomodate the axle?
worX
| posted on 6/2/08 at 03:23 PM |
I think it's best practice to use a two piece propshaft in most BEC applications...
tegwin
| posted on 6/2/08 at 03:24 PM |
Do you mean two piece as in, telescopic, or sepperated by a bearing block of some type(basically two propshafts, so 4 UJs) ?
[Edited on 6/2/08 by tegwin]
welderman
| posted on 6/2/08 at 03:25 PM |
i agree.
Coose
| posted on 6/2/08 at 03:49 PM |
As you said in your first post - a two-piece prop with a centre-bearing and a sliding joint.
Spin 'er off Well...
tegwin
| posted on 6/2/08 at 03:53 PM |
Hmm...
Where to I find such a beast?
Anyone got any photos?
I have a telescopic prop that bolts onto the axle, so that bits sorted...I just need to link engine to prop....then prop to prop
smart51
| posted on 6/2/08 at 04:26 PM |
my prop shaft is actually 2 props, with 3 joints. One at each end and one in the middle. The front prop shaft has a sliding bit and the centre joint
is mounted on a membrane that allows fore-aft movement.
[Edited on 6-2-2008 by smart51]
| posted on 6/2/08 at 06:10 PM |
you need it in two pieces (ie uj in the middle) because it would be longer than a car shaft and would need to be about 6" to overcome
vibrations.
