Author: Subject: Steering wheels for a Sierra column.
bigandy
posted on 1/3/08 at 05:07 PM Reply With Quote
Afternoon folks.
I am just wondering about the steering wheel for my car, and I could do with a bit of advice. Basically, I have a Sierra steering column in my car, and currently a sierra steering wheel (the one that is held on with a single nut). I want to fit a smaller wheel, preferably one with a flat bottom section, to maximise the amount of legroom I have.
Now, it seems that most aftermarket steering wheels like this need a boss to mount to. However, the ones I have seen all seem to be "weld on". I was hoping that I could get one that simply bolts in place, althugh I am not sure if these are available. If anyone has any links to suitable bosses, I would be very grateful , thanks.
Dammit! Too many decisions....
tjoh84
posted on 1/3/08 at 05:26 PM Reply With Quote
hiya dont know bout the s/wheel but just reading post bout the flat bottom sounds like you might get more room in str8 line untill you have a corner and have to turn the wheel
Humbug
posted on 1/3/08 at 05:42 PM Reply With Quote
For the traditional Mountney style steering wheels you can get bosses for loads of different types of cars, including Sierra. They just bolt on to the column with the original nut. I['m sure other makes have different bosses available as well.
The other thing is that with a smaller wheel you probably don't need a flat bottom on it. Not sure how wide a Sierra wheel is, but my Mountney is 11" in diameter - I'm guessing that the Sierra is probably at least 14", so you've saved 1.5" of knee room already
Schrodinger
posted on 1/3/08 at 10:05 PM Reply With Quote
I used the Mountney D steering wheel and their boss which just bolts on to the column
Keith
Aviemore
jimgiblett
posted on 1/3/08 at 10:50 PM Reply With Quote
I had a Momo Team on my Phoenix (best of both worlds IMHO. It is asymetrical but still round if that makes sense so no problem of a flat bottom but more legroom. With a quick rack you dont twirl the wheel much anyway.
Linky to DT but you can prob get it cheaper elsewhere.
- Jim
Simon
posted on 2/3/08 at 12:35 AM Reply With Quote
If you do change the steering wheel, take the Sierra one to the test with you.
My examiner failed my car with aftermarket wheel - said it wasn't part of a type approved (steering) assembly. Utter bull in reality.
Retester (different chap) saw Sierra wheel (and other mods I had to do and passed the car. He then said "I bet that wheel's not staying on there".
"It'll be changed before you get back with my MAC" was my reply
Simon
richard
posted on 2/3/08 at 09:46 AM Reply With Quote
Agree with most of these commnets, me and my build partner have left the sierra one on for the test, but already tried the after market one ( with a flat bottom )we have bought with a bolt on adaptor available from the same place and as he is a bit taller finds it impossible to use car with the original sierra one.the new one with the original rack is brillant. Cannot wait to junt the old one ater the SVA.
bigandy
posted on 2/3/08 at 10:00 AM Reply With Quote
Cheers folks,
I knew there had to be a suitable boss out there, I just couldn't find it. I guess I didn't look hard enough
Speaking of the sierra wheel, with that fitted, I can only just get into the car, and it will be bordering on unsafe to drive it I think!
Simon
posted on 3/3/08 at 12:28 PM Reply With Quote
Correct, I had just that trouble - my legs were rubbing the wheel all the way to the test centre. Rules, not practicality come into play here I'm afraid.
Simon
