Author: Subject: What size brake hose nuts do I need??
mattgriffiths2002
posted on 6/3/08 at 06:06 PM Reply With Quote
Hi guys,
Does anoyone happen to know what size nuts I need to fit my standard ford brake flexi hoses? They look about 10mm or there abouts but are they a particular thread or anything?
It is for the join basically between my flex and copper pipe. I have made a bracket on the chassis with a hole in it. I am putting the thread on the flex through the hole, then the nut (which I am trying to find) on the other side to fix it to the bracket and then the copper pipe with the female join goes on after that.
So I know it sounds a bit long winded but all im after is the nut size to fit the thread on my flexi hose,
Thanks,
Matt
jollygreengiant
posted on 6/3/08 at 06:10 PM Reply With Quote
Pop into a motor factors and ask for some std metric brake pipe nuts. Either male or female as applicable.
turbodisplay
posted on 6/3/08 at 06:21 PM Reply With Quote
Normal size is m10 * 1mm pitch half nut.
Darren
russbost
posted on 6/3/08 at 07:55 PM Reply With Quote
Confirm M10 x 1.0 half nuts
