Author: Subject: Can wilwood handbrake cable be shortened?
cloudy
posted on 7/3/08 at 10:16 PM Reply With Quote
Rally Design say the outer is 2meters long! I have barely a 1m run to the handbrake - Is the cable able to be shortened with ease?
bigrich
posted on 7/3/08 at 10:28 PM Reply With Quote
yes it can be shortened.
I just removed the inner cable then measured and cut through it with an angle grinder with a cutting disc.
Rich
cloudy
posted on 7/3/08 at 11:50 PM Reply With Quote
excellent - thanks
posted on 8/3/08 at 09:36 AM Reply With Quote
A good trick when shortening inner cables is silver solder the bit you are going to cut before you cut it -- this prevents the cable fraying.
