se7ensport
| posted on 11/3/08 at 10:05 PM |
Wilwood Smart Pads v's M1144
The topic came up on the group buy in the forsale forum, this seems a more appropriate place to have the discussion:
quote: Originally posted by se7ensport
quote: Originally posted by procomp
Hi forget the smart pads. They are either to hard by far or dont last the distance depending on which ones you use.
Cheers Matt
Hi Matt
I'm curious about the difference between the pads - having looked at the friction versus temp graphs the smart pad sits between M1144 and M1155,
so where do the M1144 out perform i.e. feel etc...
I've already got M1144 in my sierra calipers and don't want to take a step backwards in performance.
Smart pad graph
M1144 graph
M1155 graph
So without buying different pads how can you compare them?
as another option I am looking it to Hawk Black.
skydivepaul
| posted on 11/3/08 at 10:19 PM |
unless you are overheating your 1144's dont bother looking to change them.
1155 's are hard and for very spirited track and race use only especially in a light car.
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
se7ensport
| posted on 11/3/08 at 10:22 PM |
I was looking at going to wilwood smart pads when I change calipers, price wise smart pads are £16.75 v's £49.50 for M1144s. I have M1144s but
they won't fit my new calipers
skydivepaul
| posted on 11/3/08 at 10:35 PM |
I used EBC red stuff pads in my willwood calipers for my Pug 205 GTI. pretty good and only got a very slight brake fade after about 10 laps at full
speed.
iirc they were about 30 quid for a set.
dont use the green stuff pads though they are sh1t.
HD CCTV
IP security systems
RazMan
| posted on 12/3/08 at 12:21 AM |
I havent used the Mintex pads so I can't offer any comparison, but I find the Smart pads pretty good for fast road driving. I havent made them
fade yet but track use might eventually change that
Raz
procomp
| posted on 12/3/08 at 08:29 AM |
Hi all i can say is that with 4 cars racing on the power light setup. And having tried ALL the available willwood pads NON where suitable. REMEMBERING
that until two weeks ago no other pad was available as a direct replacement. We where machining other pads and making them fit ( 3 hours of work per
set ) so that we could use the powerlight calipers.
Now the MINTEX 1144's are available i will be running those. Or rather trying those out. But i am not expecting there to be any problems. Once
we had the other pads to fit. The calipers worked very well and without problems.
The big problem with pads is that every one has there own favorites. But as i have always said between Ferodo mintex EBC. There is very little
difference in performance. It is usually different people with different braking systems and different driving styles that are the biggest difference.
Hence one will say they hate one brand but then many others will say i wouldent use anything else.
HTH cheers Matt
