gr8ging
| posted on 16/3/08 at 05:34 PM |
rear brakes
At the mo I have some reconditioned sierra rear calipers, one of which the hand brake mechanism seems a bit iffy. I've seen some hydro
mechanical ones on rally design (see below link). Will they fit the sierra rear hubs?
They mention they are 1kg lighter than sierra but i think they maybe for a golf?
Anyone know if they fit, or what have you guys used insted of std sierra calipers?
http://www.rallydesign.co.uk/product_info.php?cPath=562_588&products_id=10563
Weaseling out of things is what separates us from the animals.... except the weasel.
You couldn't fool your own mother on the foolingest day of your life with an electrified fooling machine!
| posted on 16/3/08 at 06:22 PM |
The word on the wires that these will fit however ---
Most likely reason for the handbrake mech being iff is the handbrake cable being to tight or the hair pin pull of springs on the caliper are iffy.
If you slacken back the cable and make sure the cable is getting fully pulled of by the spring the self adjuster should work. It used to be
recommended to fit Granada pull off springs which are apparently stronger but might be very difficult to get.
