Author: Subject: Brake disc retaining bolts????
plantman
posted on 21/3/08 at 08:51 PM Reply With Quote
When I removed the disc from my cortina uprights, the M10 retaining bolts were 10.9 spec.
1. what spec bolts have everybody else used??
2. Or where could I get some from?
cheers
Howlor
posted on 21/3/08 at 09:06 PM Reply With Quote
You should be able to get 10.9's from any nut bolt specialist. If you are struggling then I think that all socket cap heads are 10.9 as standard.
plantman
posted on 21/3/08 at 09:27 PM Reply With Quote
They have to be hexagonal head bolts for the locking tabs to work.
Which bolt specialist?
RazMan
posted on 22/3/08 at 05:10 AM Reply With Quote
No need to use locking tabs nowadays - Locktite will do the job nicely.
Raz
plantman
posted on 22/3/08 at 01:05 PM Reply With Quote
will that pass the sva??
RazMan
posted on 22/3/08 at 02:45 PM Reply With Quote
Mine did TBH I don't think it is an SVA point and as long as the disc is not falling off, causing the brake action to fail, it should pass.
[Edited on 22-3-08 by RazMan]
Raz
plantman
posted on 22/3/08 at 08:07 PM Reply With Quote
cheers that will do
Coose
posted on 23/3/08 at 06:56 PM Reply With Quote
A drill and some lockwire is a better option...
Spin 'er off Well...
