stuart_g
| posted on 29/3/08 at 09:00 AM |
flexi brake pipes
Can I use rubber petrol pipe between my brake fluid reservoir and the master cylinder. Will it be ok with brake fluid?
[Edited on 29/3/08 by stuart_g]
x_flow57
| posted on 29/3/08 at 09:38 AM |
Unfortunately no, for SVA it needs to be properly marked as suitable for brake fluid. Fuel pipe is also "porous" when used for brake
fluid.
I found Think Automotive in Isleworth, had what I needed, some have found a Fiat part fitted but they wern't big enough bore for mine.
<<<<<<For Sale
Nick
[Edited on 29/3/08 by x_flow57]
| posted on 29/3/08 at 09:40 AM |
http://www.improve-tuning.nl/vermogen/FSE/images/Hosedesc.pdf
suggest some fuel hoses are, some aren't....
either way Mr SVA won't be happy....
True - brake fluid is really quite unpleasant stuff: inflammable, melts paint, mucks up some forms of rubber, and so on.
You just have to use the proper stuff, else you'll end up with leaks (or worse).
nitram38
| posted on 29/3/08 at 09:50 AM |
u2u Russ Bost.
He does braided hoses very cheaply, with all of the unions etc.
RazMan
| posted on 29/3/08 at 10:07 AM |
The correct pipe will probably have a blue inner liner and a cotton outer braid. As already said, fuel pipe will 'sweat' and you will end
up with brake fluid everywhere in a few weeks.
Raz
Johneturbo
| posted on 29/3/08 at 11:37 AM |
Hey Stu,
i've had the same dilemma, as my 10mm fuel hose supplied won't really be upto the job!
i did buy some small fuel hose, but looks like i'm gona have to change it.
this from merlin should be fine, can also get a letter of compliance
http://www.merlinmotorsport.co.uk/BRAKE-&-CLUTCH-PARTS-Reservoirs/c29_160/p1931/8MM-REMOTE-RESEVOIR-HOSE-100MM/product_info.html
stuart_g
| posted on 29/3/08 at 05:20 PM |
That is perfect John, cheers for that.
I did ring Rally Design on Friday as I seem to remember someone on here saying they got some from them but they didn't know what I was going on
about
eccsmk
| posted on 29/3/08 at 06:01 PM |
i used russbost top bloke very helpful
MikeR
| posted on 30/3/08 at 10:08 PM |
rally design can't supply the letter of conformity and it doesn't have markings on. I asked them, although it is from Girling in the
states so they assure me it will be ok.
except mr SVA won't take that assurance. Anyway, i've got my source i just need to pop round and see him sometime.
