eddbaz
| posted on 27/4/08 at 03:36 PM |
wilwood brake fluid
I'm using wilwood powerlites front and rear,can you tell me the correct brake fluid to use?
mookaloid
| posted on 27/4/08 at 04:01 PM |
If it is a new system which hasn't seen brake fluid before, then I would use DOT 5.1 which is a good normal spec fluid.
Some info here
eddbaz
| posted on 27/4/08 at 04:19 PM |
yes it is a new system,I know on some systems dot 5 isn't recommended as it can damage the seals,dot 5 seams to be the one to go for as long as
the wilwoods are compatable.
indykid
| posted on 27/4/08 at 04:42 PM |
i've never heard a good word said about dot 5. the disadvantages seem to far outweigh the advantages.
stick to dot4 or dot5.1 as mookaloid says.
tom
| posted on 27/4/08 at 06:52 PM |
DoT 5 and DoT 5.1 are very different
Use DoT 5.1 and change it at least every 2 years to preserve the higher boiling point and keep up the level of corrosion inhibitors.
If you can't be bothered changing it just use DoT4 as it is bit less hygroscopic.
DoT 5 is only really good for classiv vehicles in very long term storage.
