marco
| posted on 2/5/08 at 11:38 AM |
Mk Indy Geometry confirmation
I'm checking my geomtry at the weekend with some proper tools for the job.
Can you confirm the settings as
Front 0.5 to 1 Degree Negative camber
Rear 0 to 0.5 Degree Negative camber
Front 1 degree toe in
Rear 1 degree toe in
These seem to be the common settings i've found through searching.
Don't think castor is adjustable is it?
mike smith1
| posted on 2/5/08 at 11:46 AM |
IIRC ours is set at:-
Front 1° negative camber
Rear 1° negative camber
Front 1° Toe in
You cant adjut the toe out/in on the rear.
Mike
mookaloid
| posted on 2/5/08 at 12:10 PM |
I would give it a bit more rear camber say 1.5 deg
Straight ahead or 0.5 deg front tracking
Rear can be adjusted by shimming the hubs on the uprights if required.
mark
