Author: Subject: Self centring - again
JeffHs
posted on 17/5/08 at 05:15 PM Reply With Quote
Well I've spent a week chopping the body work off, grinding off the top wishbone mounts, fabricating new mounts 25 mm further back, so I've now got 5 degrees of caster, and re-skinned the body, and the sodding thing still doesn't self-centre.
Admittedly only tested in the driveway - daren't risk a road test, with my luck I'd get nicked like Fatty Soames.
philw
posted on 17/5/08 at 05:32 PM Reply With Quote
We are talking negative caster? i thought three degrees was about right
paulf
posted on 17/5/08 at 06:05 PM Reply With Quote
I modified my wishbones to give 5 deg as the book measurements are wrong.
I find it does self centre but not as much as a modern tin top however it did pass sva and ive never had a problem with it.
Paul.
nitram38
posted on 17/5/08 at 06:51 PM Reply With Quote
Why didn't you remake the top wishbone rather than move the mounts?
All though not a 7 my F1-2 has 7 degrees of castor and it centers well.
pajsh
posted on 17/5/08 at 07:49 PM Reply With Quote
When mine failed SVA I measured it and it was about 2.5 degrees (book chassis so probably built wrong).
Modified the top bones and set up about 6 degrees and it passed OK.
I also used all the toe out/tyre pressure tricks but I'm not sure they made a big difference. Feels much the same now I've set the pressures and toe in back.
I used to be apathetic but now I just don't care.
Bob C
posted on 17/5/08 at 07:59 PM Reply With Quote
Just remaking the 'bones can give clearance problems between the 'bone tubes & the spring - otherwise it's a choice of what's easier - remake wishbones or move brackets.... tough call!
adithorp
posted on 17/5/08 at 08:50 PM Reply With Quote
Unless you drive it you'll not know. It only has to have "a degree of self centering". They test it by driving on almost full lock and let go of the wheel. You won't notice that on the drive.
adrian
RazMan
posted on 18/5/08 at 05:56 AM Reply With Quote
I thought mine would fail (about 5 degrees castor but stiff) but luckily it passed without issue.
As said, Mr SVA will mostly test on full lock and most cars will have a small amount of self centreing like that anyway.
Raz
saigonij
posted on 18/5/08 at 08:05 AM Reply With Quote
what about springs at the end of the steering rack - i dont know the exact details but i swear i read it on here somewhere...
Mark Allanson
posted on 18/5/08 at 12:04 PM Reply With Quote
A total bodge, better to do the job right, this may help
http://locostbuilders.co.uk/viewthread.php?tid=89365
It seems that the self centring issue applies mainly to sierra hub carriers, tina ones do not seem to have the same problems
