Author: Subject: Steering Arms
posted on 23/5/08 at 10:46 AM Reply With Quote
Steering Arms
Having got hold of a second hand steering rack to cut down, we noticed that the steering arms move much more freely than the ones we have. When removing the boots on the latest rack, there was plenty of oil/grease sloshing about and the steering arm balljoint casings seemed to have channels/oilways. As a result, there seems to be little/no resistance and they move quite smooth and freely. The original steering arms we have, do not have the channels in the balljoint casing and there is much more resistance in the joint movement. Are both types of joint normal and which would be best to use on the Indy?
Phil
posted on 23/5/08 at 02:30 PM Reply With Quote
would it help to say what car make/model the rack is from?
If memory serves me well, the mk2 escort haynes manual shows springs that set a preload on the arms, there is description of how to set ip up too using a string and spring balance - maybe you need to do that?
mark chandler
posted on 23/5/08 at 03:39 PM Reply With Quote
New racks are very stiff, old uns lossen up, a lesson in life !
I guess you have a mid 30's rack to hand!
posted on 23/5/08 at 04:20 PM Reply With Quote
Sorry guys, I thought it would have been obvious from the Indy remark thats it's Ford Sierra gear............. It's not the rack that's stiff. I'm talking about the movement of the actual balljoints on the steering arms.
Phil
mark chandler
posted on 23/5/08 at 04:24 PM Reply With Quote
So was I ! the bits that wobble, cup and ball.
Very stiff when new, there is a lot of leverage on these when you turn so it will have little to no effect when you drive.
Regards Mark
posted on 23/5/08 at 04:55 PM Reply With Quote
There appears to be two different types of Sierra steering arms. One type has channels in the cup (presumably for oil/grease) to lubricate the joint, whereas the other type doesn't have these.
Phil
