tegwin
| posted on 25/5/08 at 01:01 AM |
Midget axle....replacing the diff unit?
I have a Midget (BMC) Axle in my car....
Bought a different ratio diff unit (complete diff with casing and gears etc)...
Can anyone tell me how to swap the diffs over?...
I cant find a decent assembly drawing anywhere!
www.verticalhorizonsmedia.tv
| posted on 25/5/08 at 05:41 AM |
Pull the shafts swap the complete diff carrier end of story. --- procedure exactly as english axle.
| posted on 25/5/08 at 09:12 AM |
As BT says . Remove wheels and brake drums, undo screws in end of halfshafts , sharp tap on end of shaft and pull them out. You may need new gaskets
and "o" rings ? Disconnect prop from diff, undo ring of nuts and Roberts your parents sibling.
