Author: Subject: Another VW rear caliper question..
Alan B
posted on 29/5/08 at 07:46 PM Reply With Quote
The pipe connection appears to be M12 x 1.0....what is the usual method? Flexi screwed straight in with crush washer or flexi attached to a banjo?...or something else?
Cheers, Alan
Syd Bridge
posted on 29/5/08 at 07:51 PM Reply With Quote
I'm about to solve this one myself very soon.
Appears that a custom banjo of some sort is necessary. I've spoken to Goodridge, and they didn't have anything off the shelf that was a correct fit.
Syd.
Alan B
posted on 29/5/08 at 07:56 PM Reply With Quote
If I hear anything I'll let you know....someone must have done it already though.
martyn_16v
posted on 29/5/08 at 09:15 PM Reply With Quote
That's a bit odd, they do do kits for the Golf with those calipers. GSF keep them in stock.
I seem to remember it being the flexy going straight into the caliper, no banjos.
RickRick
posted on 30/5/08 at 07:25 AM Reply With Quote
i've got the rally design ones which are supposed to be the same as the VW ones, there definatly m12*1.0 mnr supplies the pipes via goodridge, but they got them wrong a few times, i've got a banjo type fitting on the caliper end, but had to get the actual banjo bolt from rally design, as the one goodride sent was m12*1.5 however i've not hooked this lot up yet so i can't tell how well it'll actualy all fit together
Alan B
posted on 31/5/08 at 04:51 PM Reply With Quote
Thanks guys...I will report back with my eventual solution
