Author: Subject: Bias bar lock nuts
stuart_g
posted on 4/6/08 at 05:08 PM Reply With Quote
Bias bar lock nuts
Anyone know where to get lock nuts to lock bias bar, they need to have a step in them so they do not lock against the clevis but the barrel part instead. Have tried local fasteners but no joy.
markyb
posted on 4/6/08 at 05:26 PM Reply With Quote
if it is for SVA Car Builders Solutions do something that might suit
try here
stuart_g
posted on 4/6/08 at 05:57 PM Reply With Quote
Thanks for that. I was looking for a nut and sleeve as one piece. I have nuts and roll pins I think I will make the sleeve cause at £6 that's a rip off
indykid
posted on 4/6/08 at 08:03 PM Reply With Quote
try here
isn't that 15mm copper pipe a roll pin and a 7/16ths unf nut?
robbing b*st*rds!
tom
Johneturbo
posted on 12/6/08 at 04:52 PM Reply With Quote
looking at carbuilders solution, wouldn't you need 2 nuts to lock it, one at each end?
i've got some 7/16 unf half nuts i was just going to put one at each end and rolepin them. would i need a sleeve?
richardh
posted on 13/6/08 at 08:53 AM Reply With Quote
guys
i got away with 2 nylocks that i cut in half to make thinner and then just drilled 2 holes in the ends of the bar outside of ther buts and put split pins in
passed no probs
