adam1985
| posted on 6/6/08 at 05:50 PM |
fuel tank and pump
just picked up my fuel tank now ive got to fit the bike pump in it i know mk do a boss but its £25 so was thinking about welding a plate of steel to
the bottom about 15mm thick big enough for the pump then just cut a hole in it so it fits in and drill and tap the screw holes it would cost me just a
couple of quid and can do it tomorrow then aswell theres no problems doing this is there
jacko
| posted on 6/6/08 at 06:20 PM |
You must be a good welder if you can weld steel to a alloy tank
or am i missing something
adam1985
| posted on 6/6/08 at 06:22 PM |
no got a mild steel tank thats been powdercoated thats a good point whats the best way of getting some of the powder coating off
jacko
| posted on 6/6/08 at 07:12 PM |
OK sorry i would think a mini grinder will remove the coating
You have not had fuel in it have you ?
if so don't weld it
GANG
Paul TigerB6
| posted on 6/6/08 at 07:26 PM |
Your welding is going to have to be fuel tight right the way around the plate isnt it??
As above, a mini grinder or drill mounted rotary wire brush should soon have the powder coat off
adam1985
| posted on 6/6/08 at 07:46 PM |
no not had any fuel in it its brand new my girlfriends brother is a engineer so will get him to weld it for me then i will pressure test the tank
after
| posted on 6/6/08 at 09:06 PM |
Used paint stripper to remove powder coating from my wishbones, worked well
