Author: Subject: Negative Camber
mad-butcher
posted on 10/6/08 at 07:14 PM Reply With Quote
Negative Camber
I'm almost at the end of my 6 night on shift so my heads cabbaged.
need to set my car up for sva not for the trackdays it's previously been used for.
Daft question. my wheels tip in at the top is that positive or negative camber
Many Thanks
Tony
Miks15
posted on 10/6/08 at 07:16 PM Reply With Quote
negative
Davey D
posted on 10/6/08 at 07:44 PM Reply With Quote
yep. wheels in at the top is negative.. give yourself a few degrees when you go on a drift session
mad-butcher
posted on 10/6/08 at 08:07 PM Reply With Quote
thanks guys
on my indy mushrooms are forward
1.5 deg neg csmber
so all I have to do is set the tracking from 3mm toe in to either straight ahead or a couple of mm toe out to get some degree of self centering for the sva
again many thanks
Tony
