Author: Subject: holed discs ?
barrie sharp
posted on 8/7/02 at 10:10 PM Reply With Quote
holed discs ?
Hi can anyone tell me the advantage of having holes in your discs, also the differance in performance between groved discs and holed discs.
not sure if its a cooling thing or surface area thing .
or how many holes?,do the pads wear uneven?
is more better or is there a set amount
Can anyone help me with the theory about this
thanks!
UncleFista
posted on 9/7/02 at 10:46 AM Reply With Quote
Holes or grooves in the disks are there (allegedly) to give the gases that are created between pad and disk during heavy braking somewhere to escape. Unnecessary in a car as lightweight as a "7" IMHO
Tony Bond / UncleFista
posted on 9/7/02 at 11:32 AM Reply With Quote
On bikes these holes and/or grooves also help to fling water off when it's raining.
Again, not relevant to most Locosts!
barrie sharp
posted on 9/7/02 at 06:20 PM Reply With Quote
has anyone tried drilling there own holes are there any problems with it.
Jon Ison
posted on 9/7/02 at 06:49 PM Reply With Quote
Done it for off road use, not sure i would want to for road use, then again i paid for drilled discs and the buggers came coverd in swarf, so i guess they took em off the shelf n drilled em......
not sure wot insurance assessor would do/say if you ever need'd him and he found home drilled disks......
Just for fun, i have 2 fairley new cortina dics in garage, which i have drilled and used on grass cars, can somone weigh a undrilled disc and post weight, will pop into garage later and weigh one,
unsprung weitght n all that......
Jon Ison
posted on 9/7/02 at 07:01 PM Reply With Quote
Just a tad under 3kgs on cheapo kitchen scales, (don't tell our lass) how much weight did it save ?
posted on 15/12/05 at 02:45 PM Reply With Quote
this was discussed many years ago when I had my MGB.
the idea being increased surface area (maybe but you are not going to get them much air flowing through when the discs are spinning), somewhjere forthe surface water to go, less weight and deglazing pads.
you needed a stepped drill platform to turn the disc so the holes are drilled neatly. also the discs, mgb at least, are cast to you will need several drills asthey blunt quickly; 4 mm is the size that springs to mind.
also you want to drill the holes in a stepped fashion so the sweep over the whole brake pad.
JAG
posted on 16/12/05 at 12:58 PM Reply With Quote
Biggest issue I am aware of (and the reason they don't come as standard on your tintop) is the holes need to be chamfered on both sides of disc and the disc should be stress relieved.
If not the disc will crack around and between the holes which can lead to dramatically reduced braking efficiency
Justin
posted on 16/12/05 at 05:30 PM Reply With Quote
Holes should be chamfered but I think no need to stres relieve that will happen first time you warm them up.
It will help water/dust/gas clearance and help stop the pads glazing -- on cooling it will almost no effect.
On the downside it will make the discs more liable to warp. Is it worth the effort on a road or track day car --- no, on a bike or kart -- yes.
jon_boy
posted on 16/12/05 at 05:46 PM Reply With Quote
And dont forget to get all the holes exactly parrellel otherwise they will be unbalanced. Which could be a problem...
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 18/12/05 at 07:22 PM Reply With Quote
Drilling Discs
I personally would not drill discs as holes are quite a bad stress raiser, and brakes are not something to take chances with.
The way to prevent the gas build up is to mill a couple of slots in the disc with a ball end cutter (approx 4mm). The slots do not go all the way to the edge.
Look at AP racing discs for ideas.
If you do drill holes, make sure they are chamfered and then get a ball bearing and place it in the hole and hit it. This peens the edge and reduces the likely hood of a crack.
Read Carroll Smiths books, he has quite a lot of info on this subject.
John
