Author: Subject: Calling Tyre Repair Experts... !
posted on 18/7/08 at 10:25 PM Reply With Quote
Would you have any concerns running a 450bhp lightweight on nearly new tyres that have had a puncture repair???
worX
posted on 18/7/08 at 10:52 PM Reply With Quote
A repair in that area would almost certainly never just "Let Go" so you could run it with any horsepower as long as you kept your eye on it.
Having said that, why don't you just replace it? That way you will never be wondering about that rear corner letting go...
eccsmk
posted on 18/7/08 at 10:57 PM Reply With Quote
it "should" be fine
i had one in a similar place on a car tyre bug with alot less horsepower on tap
HTH
adithorp
posted on 18/7/08 at 11:05 PM Reply With Quote
Depends on the speed rating but I'd assume not. If they're above H then only the centre 80% with standard patch's.
adrian
jollygreengiant
posted on 19/7/08 at 05:59 AM Reply With Quote
Proximity to edge would make it specialist repair only depending on angle of penetration. IF repairable at specialist, then cost would have to be weighed against cost of new tyre and how comfortable you would feel about it.
nitram38
posted on 19/7/08 at 06:55 AM Reply With Quote
I had a puncture repair there on my tintop (previa) cost £18 with the balacing etc.
posted on 19/7/08 at 08:20 AM Reply With Quote
What if I told you that the tyres had 7mm left and the cost to replace both with shiny new ones is over £500
omega 24 v6
posted on 19/7/08 at 08:29 AM Reply With Quote
GULP
Well if the tyre place say's it's OK then stick with it. At least you know it's there so you can keep an eye on it. How many of us have driven on tyres with objects in them and never known?? Untill they let go. I'd go with whatevere the tyre repair places tells you.
adithorp
posted on 19/7/08 at 08:32 AM Reply With Quote
If it was mine and I was repairing it, I'd do the first one but not the second. If I had to let someone I didn't know do it then neither.
Seek out a specialist tyre repairer (not just KwikShit) and see what they say. £500 or risk yours and everybody else around you's lives?
adrian
Davey D
posted on 19/7/08 at 08:44 AM Reply With Quote
Ive had 2 tyres let go on me that have been repaired like that with a little mushroom plug. Both were on my diesel pug106, which is a very slow underpowered car.
One tyre started to bulge where the repair was, and one went bang and fully deflated whilst driving on the motorway luckily it was a back tyre, and not a front one
i have vowed to myself that in future i will always just buy a new tyre instead, but my tyres were a lot cheaper than £500
posted on 19/7/08 at 09:02 AM Reply With Quote
Cheers!
Some food for thought there!
mr henderson
posted on 19/7/08 at 09:50 AM Reply With Quote
I would say that although £500 was a lot to the rest of us, to a man of your very obvious means that £500 was what our American friends refer to as 'chump change'
John
DRC INDY 7
posted on 19/7/08 at 09:55 AM Reply With Quote
if the repair is done correctly then there is no problem trouble is there are 2 many people in the trade that think they know what they are doing when they know nowt
Puddle Dodgers Club
posted on 19/7/08 at 10:05 AM Reply With Quote
No - not chump money to me... it's a bloody lot! Hence the reason I'm debating going down this route! Unfortunately, 315 section tyres don't come cheap, so you HAVE to pay what they cost.
PS - It might surprise you how prudent I've been with my build costs on the Ultima. It's being built to a definite budget - hence the reason it's taking so long to complete!
If I was indeed 'man of very obvious means' then it would have been finished a long time ago, and I wouldn't be farting about with second hand engines, repairing OEM manifolds and discussing plugging tyres!
mr henderson
posted on 19/7/08 at 10:22 AM Reply With Quote
I'll consider myself soundly b0ll0cked
John
[Edited on 19/7/08 by mr henderson]
C10CoryM
posted on 19/7/08 at 05:50 PM Reply With Quote
For tires rated to 130mph, you are typically allowed to repair one puncture per tire w/o affecting the rating if:
Hole is less than 6mm
Hole is between the outside grooves (yours are not).
You use a plug and patch system (combi patch)
Tires above 130mph, no repairs permitted while retaining the speed rating.
While you could safely patch those holes for normal street use w/o any worrys, I would not use them for high speed events. Certainly not a track day. If in doubt, email the tire manuf for repair info.
Cheers.
Cory
[edit] btw, this would be a good chance to buy some track wheels/tires and just run the damaged ones on the street
[Edited on 19/7/08 by C10CoryM]
"Our watchword evermore shall be: The Maple Leaf Forever!"
posted on 19/7/08 at 06:14 PM Reply With Quote
(1) Both holes are on the tread area of the tyre
(2) The tyres are steel belted radials.
This type of puncture would normally be repaired by vucanising a plain patch on the inside of the casing.
During repair UK law demands the tyre be visually examined internally and externally for damage and any debris clean out from the casing.
Mushroom type repairs are not suitable on steel belted tyres because to insert them damages the steel belts and in any event the edges of steel belt would cut through the stalk part of the plug.
Having said all that with the ammount of power you have using tyres that you could have any possible doubt about is silly.
posted on 19/7/08 at 06:27 PM Reply With Quote
Mushroom type repairs are not suitable on steel belted radial tyres because to insert them damages the steel belts and in any event in use the edges of steel belt would cut through the stalk part of the plug.
JamJah
posted on 22/7/08 at 03:22 AM Reply With Quote
10 rons for a full set of tyres inc spare. my!
This is personal advise or personal opinion.
Constructive comments gratefully recieved, picking is left for noses.
jamie1107
posted on 27/7/08 at 12:45 PM Reply With Quote
with that much power tyres can rotate on the bead of the wheel rim sometimes the inside and outside beads do not rotate at the same rate thus twisting the tyre hence why drag racing cars sandwich their tyres between two beads which could dammage the securing pad of the plug
im my experiance i would have refused to repair that puncture because it is not in the central portion of the tyre although i must admit if it was my own car i would plug it and fill the tyre with the puncture repair gue you can buy from halfrauds just in case
That way if it goes which as people have rightly said they seldom do it will go down slowly a blow out is not a pleasnt thing
i cant remeber the exact reason for only repairing the canter section 75% of the tyre width but that advise came from the dunlop training rep when i did my apprentaship
i know the tyre is going to be silly money but if you write off the car for a 500 quid tyre you are going to be even more pissed off
besides im sure somone will give you stupid money for the repaired one on good old ebay
[Edited on 27/7/08 by jamie1107]
