Author: Subject: brake master cylinder, what to do?
ditchlewis
posted on 23/7/08 at 06:47 PM Reply With Quote
i'm about to repair my braking system.
i has 2nr 90mm master cylinders (bolt hole spacing) which have failed, and one 70mm master cylinder which i bought off ebay unused but old stock and so may have been standing for years.
the car has been built around the 90mm master cylinder and i have a repair kit on order.
should i repair the old master cylinder (one of which is 3 years old and only has 800 miles of use (must have failed due to not being used and dried seals) or should i cut the pipework around and drill more mounting holes and use the smaller one?
what i don't use i will repair or put on ebay.
what to do?
which were the best?
ditch
[Edited on 23/7/08 by ditchlewis]
daviep
posted on 24/7/08 at 06:48 AM Reply With Quote
Have patience and wait for the repair kits to arrive, that's my opinion anyway.
Davie
Bluemoon
posted on 24/7/08 at 08:56 AM Reply With Quote
Repair kit first...
Dan
Stuart_B
posted on 24/7/08 at 12:47 PM Reply With Quote
hi, where did you get the repair kit from? i need to fix mine.
thanks
stuart
