dave1888
posted on 27/12/03 at 05:42 PM |
Oh dear my shaft is to long
Just tried fitting the steering column to my cat e1 and discovered the column is to long. The length between the mounting holes and the end of the
outer tube.
Is there a difference between years of sierra mines a 1989 2.0i estate
givemethebighammer
| posted on 27/12/03 at 09:30 PM |
how much too long ?
Are we talking centimeters or milimeters ?
Mark Allanson
| posted on 27/12/03 at 09:35 PM |
Are we thinking colapsable columns again? I know there is a length difference between the adjustable and the normal, I have a non adjustable power
derived column if you need any measurements.
| posted on 27/12/03 at 11:02 PM |
likewise, i have a non adjustable non powered one if you want measurements off that...
dave1888
| posted on 28/12/03 at 10:50 AM |
Thanks for responding, problem solved. For some reason it now fits. (think maybe i was doing it wrong)
| posted on 28/12/03 at 12:34 PM |
You can loosen the pinch bolt on the top sierra mount and get about an inch of play either way. I did it on mine and you can mount the column in
front or behind the top mount to get a bit more adjustment. Mine is a book chassis but it should apply to other types.
yours, Pete.
