The Baron
| posted on 18/8/08 at 03:38 PM |
Suspension Bits.
Sod's Law,
I need to make some new top, front wishbones, I was going to use those camber adjusters, which were in plentiful 'but it now' supply on
ebay. when i want some,,,,,none
Ok, i'll use the traditional M18 internally threaded bar, same sodding problem......
grrrrrrrrrrrrrrrrrrrrr
B.......
Miks15
| posted on 18/8/08 at 05:11 PM |
Rally Design do some here
The Baron
| posted on 18/8/08 at 05:30 PM |
Mmmmmm, they want more for P&P that what the adjusters cost, which aggravates my wallet ?
Bugger
Miks15
| posted on 18/8/08 at 07:53 PM |
i think if you call them they will send them out cheaper. The internet P+P is the standard delivery charge but if you call them i think ive heard they
will send it out standard rate, they are light and not massive either.
clairetoo
| posted on 18/8/08 at 08:34 PM |
Did you mean
these ? (allthough at 30mm dia they do look a bit heavy...)
Or there are some
here
as well
[Edited on 18/8/08 by clairetoo]
Its cuz I is blond , innit
Claire xx
Will weld for food......
