Stott
| posted on 28/8/08 at 03:08 PM |
Master Cylinder Bendix/Girling?
Afternoon all,
Been trying to find a seal kit for my Sierra 86' M/C today.
My ford dealer said there are 2 types of M/C on my year of donor, Girling or Bendix and he can get a seal kit for either, £30 + VAT.
Problem is we are having trouble ID ing the cylinder as it has no external or internal marks to give it away, can anybody shed some light on which
type it is?
I have more massive massive pics if this helps, info on the cyl is 74660862 P on one side, the alphabet A-O and SQ103 on the other, also 66315 04
38/6/2 27AV on the plastic loop tag?!?
Alternatively can anyone suggest a replacement M/C with correct orientation mounting holes?
Thanks as always
[Edited on 28/8/08 by Stott]
JAG
| posted on 28/8/08 at 03:20 PM |
74660862 P
This alone tells me that it is a Girling m/cylinder. I used to work for what's left of them (now TRW Automotive) and that is their part No -
probably for the master cylinder body casting.
HTH
Justin
theconrodkid
| posted on 28/8/08 at 03:21 PM |
its the number on the plastic tag they need,have you tried www.brakeparts.co.uk,may be better to get a new master instead
who cares who wins
pass the pork pies
James
| posted on 28/8/08 at 03:25 PM |
Took me ages to find a seal kit for my leaky one. Eventually found one on ebay.
Fitted all seals etc. bloody thing never worked properly after that.
So bought another m/cyl from someone on here.
That's a helpyful post, isn't it!
James
[Edited on 28/8/08 by James]
- Muhammad Ali
Stott
| posted on 28/8/08 at 05:32 PM |
Thanks for the help, the plastic tag No didn't help the guy in Ford
Do you think £30+Vat is reasonable for a seal kit? It works great just weeping a little on the rear seal out to the pushrod, Been quoted circa £100
for a new M/C
Stott
| posted on 28/8/08 at 05:37 PM |
Just spotted this:
http://cgi.ebay.co.uk/FORD-SIERRA-SAPPHIRE-BRAKE-MASTER-CYLINDER_W0QQitemZ350090877892QQcmdZViewItem?hash=item350090877892&_trkparms=72%3A12%7C39%
3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Does anyone know if this will fit my resevoir and hole orientation? The outlets being the other side is of no importance however it does confirm mine
is a girling.
