Hi,
Has anyone got a Greengauges speedo and know if it has a white plastic plug on the back for the wires as a pose to terminals? (Just like the rev
counter)
Pat...
Can check mine for you ,but it will be saturday afternoon before I can get to the car Rusty
Mine had a plug with wires connected, just fit to car loom and then plug into speedo.
Mine has a white plastic plug.
mine has a small multi plug , also ref your other post about fuel gauge had problem with mine reading incorrectly, removed sender with wires attached and moved float by hand. found sender was assembled with float upside down even though I had assembled it according to downloaded instructions, nice instruments. Rusty
Cheers Rusty.
I figured the small box thing out after a bit of head scratching!
Just got to save up for the speedo now. Got all the other dials!
Pat...
