Hi peeps,
Do most people carpet their cars themselves?
Are there companies which will do this for me?
Would you say it was possible to easily and within a short space of time (as we all know cost is inversely proportional to time on our
cars
) have my car carpeted for less than £300?
ETA - I'm just after that normal thin black carpeting stuff, no pockets or anything fancy. Yellow stitching at the most.
Thanks!
[Edited on 22/4/10 by cd.thomson]
what your dax?
why would you want to?
THink of all that extra weight
Why cant you do it? 300 will carpet it in shaggy wool pile..or axeminster.
Not concerned about the extra weight, as we all know the Dax isn't the lightest of the sevens anyway
. Theres some chips on the tunnel and some
EXTREMELY suspect fibreglass alterations to the end of the drivers foot well panel that I'd like to cover up.
Main reason I'd like to avoid doing it myself is that I can't even wrap a CD at christmas so the thought of stitching well sized bits of
carpet together and making the necessary releving cuts etc fills me with dread!
i see your chips and dodgy glass work, and raise you rust stains and a cardboard seat. So there.
ps, i found it a lot lighter with no seats, dash, tunnel cover etc.
[Edited on 22/4/10 by JoelP]
I reckon you should go for yellow shagpile, will look good. Promise
Carpets nice, soaks up the rain real well
Did my MK for less then £30.
Bad move, you will regret it.. Polish out any blemishes or hide them by putting something over it such as tax disc or pocket
Hmm so I'm guessing from the responses that I should just buy 50m2 of black carpet and try my very hardest?
Could someone at least tell me how people attach it? Contact adhesive?
Should I just do each face slightly oversize then stitch them all together so I end up with a shaped piece of carpet for the two passenger
compartments, the tunnel and the rear bulkhead?
Originally posted by eddie99
Bad move, you will regret it.. Polish out any blemishes or hide them by putting something over it such as tax disc or pocket![]()
Originally posted by couch22k
Did my MK for less then £30.![]()
Why will I regret it?
Better than scratched ally floor panels, dodgy chipped GRP edges and chassis members to look at surely?
I made carboard templates of the panels, and just used carpet spray adhesive £3 a can, leave it for a few minutes till it's just tacky (Sticks
like SH*T)
And don't drive in the rain.
Not got carpets myself, but I remember seeing a tip in Which Kit? or some such: for the floor bits, make slightly undersized templates from thin ply
sealed with PVA or something, then glue the carpet onto the plywood and fold over the edges, glueing and stapling the folded over bits as well. That
way, if it does rain, you can remove them for drying out.
Simon
ETA 50m2 seems a bit excessive! 2 m2 would probably do it!
[Edited on 22.04.2010 by Humbug]
Mines carpeeted, so much nicer that painted metal evrywhere
Also , when it gets wet, drys in a few hours, so not a problem
I use this for paneling the boot instead of ally, don't see why you can't use it instead of carpet.Carpeted panels
Carpeting
Use adhesive from wickes (you have to ask for it) I used the orange piping to stick to the carpet. The sides are stuck to thin ply and velco'ed
into place so I can remove them if I like.
Just take your time cutting each piece out and make small cuts at a time and re-measure.
Helps if you get her in doors to mess with the sticky stuff!!!
Finshed carpeting
i'd be worried about the water trapping rain water and rusting the chassis or other steel bits
What about this: Ebay
