Had a fairly productive weekend. Sorted out my ignition problems by replacing the points dizzy with the early points-less one with amplifier module
and it works fine
Also sorted out the tunnel cover and finished off the interior, just need to sort out a centre for the small wheel that I will be fitting after IVA.
Also need some gaiters for the sticky up stuff (I bought one for the gear stick ages ago but I'm bu**ered if I can find it
All comments welcome (nice ones even more so though
Interior 1
Interior 3
JB
Looking the mutts nutts - you're definitely making progress.
I'm sure someone that's been through IVA will come along soon to point out if there are any edges that look improperly radiused or other
similar issues...
I had the same gear knob, was told it will fail as the edges are sharp, stuck the standard Sierra one on for the IVA.
