When I tighten up my eye bolts they are not in the best position to clip the harness on, am I best to shim them so they tighten in the correct position or is there a tried, tested and accepted method of fitting eye bolts? (I will be putting them in with blue loctite threadlock)?
Try swapping them around as the treads will all be slightly different so you might find a combo' that does line up. After that you'll have to shim them with washers.
Why do you need threadlock? with a harness attached they will never be able to rotate and come undone
Originally posted by peter030371
Why do you need threadlock? with a harness attached they will never be able to rotate and come undone![]()
I have, after trying various eyebolts, managed to get the drivers lower mounts fitted. These are as per book fully welded 7/16 UNF nut on 5mm plate,
also fully welded. I note that on some SVAs it is commented that would be better with fillets to support the brackets, any body know of any SVA
failures with just fully welded 5mm plate?
Also, the mounting clips on the Securon 655 harnesses have a small hole that something like a split pin could be inserted preventing the clip from
being removed. I think that this may be a good idea on my car as accessing the lower seatbelt mounts involve a pain in the backside job of removing
the front seats.
Originally posted by craigdiver
I have, after trying various eyebolts, managed to get the drivers lower mounts fitted. These are as per book fully welded 7/16 UNF nut on 5mm plate, also fully welded. I note that on some SVAs it is commented that would be better with fillets to support the brackets, any body know of any SVA failures with just fully welded 5mm plate?
Also, the mounting clips on the Securon 655 harnesses have a small hole that something like a split pin could be inserted preventing the clip from being removed. I think that this may be a good idea on my car as accessing the lower seatbelt mounts involve a pain in the backside job of removing the front seats.
Seatbelt mounting plates are 3mm thick and 100mm long (as per Haynes roadster manual), I don't have any gussets welded in.
