Universal dash blank with SVA lower radius in fibreglass that will fit the "book" scuttles available from the likes of GTS, MK, Luego as
well as many others.
So it can be made to suit all the above it was made slightly bigger so will require trimming to suit your scuttle.
These retail eslewhere for £65.00(£85.00 in carbon fibre) but i am doing the first 10 at £45.00(65.00 in carbon fibre) on a first come first served
basis to the forum.
Mark
Are they flat across the bottom or do they have a "leg" on each side?
Like this:
Pat...
Sorry i forgot to post the picture.
They are bigger around the edge so can be trimmed to suit. I have tried it against MK's,Mac#1's,GTS, and a book lowline scuttle and with
some fanooodling with a grinder can be trimmed down to suit all of them.
Mark
Hi Mark,
Any chance of the dimensions between the inside and outside edges of the legs?
If it'll fit, I'm up for a carbon one if that's ok.
Pat...
Go on then Mark, I'll ave one
I guess it fit the blue scuttle I had of you ?
Jason
oh yeah,, F/G
[Edited on 10/7/05 by Deckman001]
Pat,
Overall length= 42"
Inside legs= 38 7/8"
Mark
If enough bodies ask(about 10 will do) i could be persuaded to make a wider version for those using the Mcsorley plans....hint hint
Jason,
Yes mate as that was the book lowline jobbie.
Eurosport tonight...Moto GP USA....the Yamaha's are in Kenny Roberts colours...yeeeeehaaaa do they look the dogs wotsits...and maybe showing my
age but that's the colour all Yamaha's should
Mark
put me on your list please
one plain one to go
To make it easier all round clicky this number into ebay.......4561601385
i have what i believe is the first carbon one mark did some time ago as a special request for me.
it's basically the same as the off the shelf stuart taylor one, but cheaper
Ned.
Indeedly you did Ned.
subject to it fitting the viento, i'll have one
cheers
Viento....is that the wide or narrow one?......How wide at widest point is the scuttle ?
Mark
will look check it and let you know
(its the wide one)
Overall width of chassis is all that is needed or where you feel dash needs to mount from on the Viento.
