gr8ging
| posted on 24/2/07 at 07:08 PM |
Bike Clocks?
How easy is it to use the standard bike clocks?
I have a ZX9r engine but I have no idea how you would incorporate/connect the bike clocks? is it easier to buy a digi dash?
Weaseling out of things is what separates us from the animals.... except the weasel.
You couldn't fool your own mother on the foolingest day of your life with an electrified fooling machine!
bigrich
| posted on 24/2/07 at 07:20 PM |
its easier to plug in the bike clocks to he bike loom and correct the speedo with a speedo healer (about 60 quid) than to wire up a digi dash
see my avatar for my speedo (06 zx10r)
| posted on 24/2/07 at 07:22 PM |
It's easy and simple to use the bike clocks, assuming you also have the loom. You'd also save yourself a few hundred quid at least.
Phil
gr8ging
| posted on 24/2/07 at 07:25 PM |
ok, I have the loom so how do I go a bout wiring the clocks up, where is the pick up point and how and where does the speed healer come into it.
desyboy
bike clocks all day long !
| posted on 24/2/07 at 07:30 PM |
Not sure where the pick up is on the ZX9 engine. The loom should have all the necessary connectors for plugging the clocks in and the speedohealer is
used to adjust your speedo reading which will be way out due to the gearing in a car application.
Phil
gr8ging
| posted on 24/2/07 at 07:33 PM |
wheres the best place to get the speedheeler from?
| posted on 24/2/07 at 07:36 PM |
You could try here
Phil
gr8ging
| posted on 24/2/07 at 07:37 PM |
Thanks for the advise
Colnago_Man
| posted on 24/2/07 at 09:47 PM |
It also depends which model ZX9R engine you have, the 'B' model (1995/1996) has a mechanical speedo which makes it very difficult to
intergrate into a car.
Only the later models with electronic speedos can easily be fitted using a speedohealer.
