Northy
posted on 25/3/04 at 10:43 PM |
Mountney wheel boss
I think the Mountney range of wheels are quite popular so hopefully someone can answer this one for me.
Does the Sierra steering column lock work on your boss? The teeth inside mine are only about 2mm high, and are no use at all as a steering lock! If
you look inside the std Sierra wheel the teeth are bout 6mm if not more!
Graham
Lightning
| posted on 25/3/04 at 11:13 PM |
All I can say is mine works OK with no mods
zetec
| posted on 26/3/04 at 03:43 AM |
Mine is fine too.
Northy
| posted on 26/3/04 at 07:52 AM |
Cheers guys,
Could you pull back the rubber cover bit and have a look to see how big the teeth are for me?
Graham
Markp
| posted on 26/3/04 at 06:11 PM |
I have the same problem, The teeth are too small and the lock just skims over them.
YOUR NOT ALONE
mark
Northy
| posted on 26/3/04 at 06:17 PM |
Mark, your car is SVA'ed isn't it?
How did you get through?
Graham
| posted on 26/3/04 at 07:02 PM |
My boss works with the Sierra column but it only locks in one position. It doesn't have teeth it has one key with a flat end that engages in a
square cutout cast in the boss. The locking mechanism is part of the column and is spring mounted so it engages when the slot is turned over it.
Markp
| posted on 26/3/04 at 10:11 PM |
Northy,
The steering lock is there as an anti theft device. I simply put an immobaliser on and it was fine. If I remember correctly I put the immobaliser
between the feed to the coil and something else (sorry) but as long as the car can't start unless deactivated then it's fine.
Mark.
Sorry can't be any more help.
Northy
| posted on 26/3/04 at 10:29 PM |
So are they all like this then? I've attached a picture of mine to show how small the teeth are. Shall I send it back?
Graham
Fifer
| posted on 26/3/04 at 10:37 PM |
Thats the same as mine. The Sierra column device catches these teeth (but not all of them for some reason on mine) and locks the wheel. The small
square cut out on the steering boss is to fit into the indicator cancelling device bush.
Northy
| posted on 26/3/04 at 10:41 PM |
But Fifer, they are no where near as long as the ones on the std Sierra wheel! The steering lock on my column just skim over the top of the teeth, no
locking action at all.
Perhaps the steering lock is worn, I'll have to investigate.
Graham
