Author: Subject: H section rubber extrusion
cd.thomson
posted on 5/12/09 at 08:55 PM Reply With Quote
Hi Guys,
has anyone tried to source some of this? I want to cut my tunnel in half (widthways) to allow easier access and want to "conceal" the cut by fitting a strip of H section rubber.
The slots should be thick enough for grp, something like 5-6mm and the total width of the strip should be about 20mm
anyone know a supplier?
Craig
austin man
posted on 5/12/09 at 09:04 PM Reply With Quote
what about the strip that they use in the backs of wardrobes to join the hardboard, would that do the trick??
Dingz
posted on 5/12/09 at 11:35 PM Reply With Quote
Baines
Try these people.
went on and on.
Blackbird Rush
posted on 6/12/09 at 07:46 AM Reply With Quote
Here you go...
Wollies linky
Or you could just run some gaffa tape accross the gap (assuming your going to carpet over it...
Mal
posted on 6/12/09 at 09:50 AM Reply With Quote
Another one is Seals Direct.
