speedyxjs
| posted on 30/3/10 at 05:17 PM |
Three point harness offset
In a previous post, it was mentioned that with a 3 point harness, the top mount should be offset by a certain amount but i cant find anything in the
manual.
Woudl it be ok to put the top mount backward so the harness goes round the back of the roll bar like this?
[img]
  Proposed harness routing
[/img]
blakep82
| posted on 30/3/10 at 05:21 PM |
very much doubt it. is it a 3 point harness, or a normal 3 point seatbelt (with diagonal top strap)?
wonder if you could use one of the roll bar bolts?
it says 8.8 grade 7/16unf or equivanlent strength, so maybe if one of those was a 12.9 and even slightly smaller than 11mm, wonder if that could work?
________________________
speedyxjs
| posted on 30/3/10 at 05:24 PM |
Its a 3 point seatbelt, sorry
How would a 12.9 <11mm bolt help?
blakep82
| posted on 30/3/10 at 05:26 PM |
well, what size are those roll bar bolts?
sorry, 12.9 grade 11mm bolt
[Edited on 30/3/10 by blakep82]
speedyxjs
| posted on 30/3/10 at 05:27 PM |
M10 8.8
blakep82
| posted on 30/3/10 at 05:30 PM |
here's what the manual says
"Note 3: A suitable single bolt fixing of adequate strength would be, for example, a bolt of at least 11mm (7/16" diameter of grade 8.8
(the grade may not be shown on a bolt produced for a seat belt anchorage). Other bolt fixings may be acceptable providing they are of equivalent
strength. Two adjacent seat belts may be secured by one bolt. In this case consideration must be given to the additional loads on the
anchorage"
so, i take that as, an 11mm with grade 8.8 is acceptable, you could go to 10mm (as per you roll bar) and using a 12.9 grade should make it stronger
than a 8.8 grade 11mm bolt
speedyxjs
| posted on 30/3/10 at 05:38 PM |
Ah, sorry Blake. The belt mounting bolt is 8.8 M12. the rollbar mounting bolts are M10 8.8 but what i wanted to know was how far from the centre of
the seat the seatbelt needs to be.
Here is a link to the previous post. Note DavidM's comment.
blakep82
| posted on 30/3/10 at 05:42 PM |
ah right, i get you.
well, i don't think it can be wrapped around a roll bar anyway, which is why i'm suggesting bolting it elsewhere.
ah, is this the answer?
"17.
A lap/diagonal belt “effective upper anchorage” location must be at least 140mm from the longitudinal centre line of the seat. (see note 14)"
i think its to nmake sure that if you did have a crash, the belt wouldn't try and slice through your neck
speedyxjs
| posted on 30/3/10 at 05:46 PM |
"17.
Ah, brilliant. Cheers Blake!
So i now need to wither change to a 3 or 4 point harness or weld a nut into the side of the roll bar.
blakep82
| posted on 30/3/10 at 05:47 PM |
i'd go with a 4 point harness tbh.
looks like you've got 2 mounting points welded in already up top. a 3 point harness will need one bolted down in the middle. 4 point will need
them sort of where you've got them welded in now
DavidM
| posted on 30/3/10 at 07:58 PM |
In the SVA manual section 5 annexe 4, seat belt upper anchorage locations are specified. It gives a minimum offset from the centre of the seat of
140mm. It's the same section that specifies a minimum height for upper anchorage points measured from a block on the seat. I'm assuming
IVA would be no less specific than SVA, but I've not seen an IVA manual.
[Edited on 30/3/10 by DavidM]
Proportion is Everything
speedyxjs
| posted on 30/3/10 at 08:15 PM |
Presumably there is no minimum distance from the longitudinal centre line of the seat for four point harness'? Have read the whole of section 31
but can only see reference to the 140mm.
blakep82
| posted on 30/3/10 at 08:17 PM |
yeah, i can oinly see 140mm thing for diagonal belts. no mention for harness belts
DavidM
| posted on 30/3/10 at 08:26 PM |
That's correct, it's only for diagonal belts. The height requirements are for both belts and harnesses.
wicket
| posted on 30/3/10 at 08:46 PM |
Standard seat belt bolt are 7/16" UNF grade 5, bolt head marks are 3 equispaced lines see here.
http://www.elginfasteners.com/metric.htm
Imperial grade 5 is metric grade 8.8 approx
[Edited on 30/3/10 by wicket]
speedyxjs
| posted on 31/3/10 at 06:15 AM |
Thats great, cheers guys
