novicebuilder
| posted on 14/4/13 at 08:33 PM |
Where do I build the seat support rails for a Haynes roadster?
In some pictures of Haynes roadsters I see that there are two floor mounted cross rails fitted between transmission tunnel and base rails on each
side, to support the seats. I haven't bought any seats yet, but I plan to have seats on runners. Should I fit these support rails, and if so
where? I want to build all chassis parts before spraying so keen to fit these parts now if possible. Grateful for any guidance about size and
position of these supports. thanks.
Talon Motorsport
| posted on 14/4/13 at 08:58 PM |
If you put them in blind with out having the seats it does'nt matter where you put them they will be wrong.
Slimy38
| posted on 14/4/13 at 09:14 PM |
Can you buy the runners to use as a template?
AdrianH
You really need to have sorted your seats and place them where needed before putting in any bracing.
If you have fixed seats without runners then this is a must. Even if you have runners you need to check the travel between the shortest driver and
tallest before fitting the fixings.
Depending on the seat make or ru8nner the holes can also be different.
So best is to get your seats first then place, sit in them and then decide fixings.
Adrian
Why do I have to make the tools to finish the job? More time then money.
| posted on 14/4/13 at 09:23 PM |
Hi do you need to have these rails or can you just fit the 100x100 plates to bolt through?????
AdrianH
| posted on 14/4/13 at 10:55 PM |
This is just a guess, but I would say possible depending on the material used for the floor and to what use the car is for race or road.
If road then the ultimate decision is on the IVA test if it passes the inspectors scrutiny.
Adrian
jps
| posted on 15/4/13 at 08:06 AM |
I've had the same challenge to overcome. In the end I bought my seats first, then made a subframe to hold the seat in the correct position from
3mm steel strip - then fastened a piece of chipboard to the underside of the chassis and plonked the seat in the car and tried the position - i.e. sat
in it with the pedal box and steering wheel in place. Once I was happy with where the seat was I marked it out, bought some runners and lined it all
up - THEN fitted the two 3mmx25 cross members once I knew where the holes for the seat runners needed to go.
I'm going to use an alu sheet for the floor - so wanted a stronger fixing for the seat - if i'd be fitting a steel floor I may have
approached it differently.
I was going to go for fixed seats initially, but didn't trust that i'd get the alignment perfect. So runners seemed essential to me...
40inches
| posted on 15/4/13 at 08:53 AM |
As all the above, but I have a steel floor and still used 25mm box section, with 3mm pads for the seat bolts.
Over kill? possibly, but I wasn't going to skimp in this area.
  Brake line
novicebuilder
| posted on 15/4/13 at 07:36 PM |
Thanks very much. Really helpful. I will buy seats first and go from there.
| posted on 15/4/13 at 07:58 PM |
I've got a steal floor and was going to add the plates underneath
