<<  1    2  >>
Author: Subject: gear lever position ?
the moa 2
posted on 4/1/05 at 09:16 PM Reply With Quote
hi,
just about to put dash board in and we have realised that the gear lever is going to hit the dash board when you put it in to 1 st , 3rd and 5th.we bent it a bit but still no difference. has anyone had this problem before.
(we ve got a pinto with type 9 box)
posted on 4/1/05 at 09:21 PM Reply With Quote
Probably worth doing a search , i'm sure this has been covered as I had the same problem and found the solution on this forum. hope this helps Rusty
tom_loughlin
posted on 4/1/05 at 09:33 PM Reply With Quote
thats wierd, i trial fitted my gearstick this afternoon and had exactly the same thought.
at exeter i saw a few solutions to this, but all of them seemed a bit bodged to me.
will be interested to see replies on this subject
Tom
CairB
posted on 4/1/05 at 09:41 PM Reply With Quote
One solution is to remove the upper portion of the gear lever.
It is connected to the lower section by a rubber junction.
I did this and found that a gear stick knob from a local factors fitted the stub when the sleeve was removed.
It makes it a tad of a quickshift but costs only a bit of time.
Colin
the moa 2
posted on 4/1/05 at 11:01 PM Reply With Quote
Missing the dash is only half the problem as ive noticed i can reach the "shifter" but its a bit of a stretch and would ideally need it closer to me.
I think it looks like we gonna have to cut and reweld it with a nice big angle on it.
Mark Allanson
posted on 4/1/05 at 11:12 PM Reply With Quote
I partially cut mine just above the damper block and rewelded - which burnt the rubber and made the lever VERY sloppy. I then had to weld a washer on the bottom of the damper to make the lever rigid!
The gear lever is now completely horizontal when in second and forth, but is very comfortable to use, and at my ideal reach. Rescued attachment Gearlever Clearance.JPG
Avoneer
posted on 4/1/05 at 11:50 PM Reply With Quote
Westie remote?
Rob Lane
posted on 4/1/05 at 11:54 PM Reply With Quote
You need a remote like this.
Ideally the gearknob when in neutral should be approx. level with steering wheel, so hand falls from wheel to gearchange naturally.
[Edited on 4/1/05 by Rob Lane] Rescued attachment Gearstik.jpg
timf
posted on 5/1/05 at 08:24 AM Reply With Quote
have a look on david jenkins website
posted on 5/1/05 at 06:33 PM Reply With Quote
Yes the David Jenkins website was very helpful shows how to make a quickshift remote, mine cost less than £1.00 to make and that was for the plastic part at the lower end of gear lever. Do a search for I can't reach my shifter, also covers this topic. Worth spending a bit of time to get it right. Also somebody was selling some remotes on this forum some time ago ,may have some left?? hope this is of some help.Rusty
albertz
posted on 5/1/05 at 08:29 PM Reply With Quote
Heres the link, incase you havent found it yet;
http://www.dwjenkins.plus.com/gear_extend.htm
I used this method and it works a treat as well as being very cheap to do. It solved the problem for me anyway.
posted on 5/1/05 at 09:41 PM Reply With Quote
Fame at last!
The only comment I can make is - don't make the gearlever too short, as the quick-shift modification reduces the leverage. I cut off the rubber damper thingy and found that the remaining stalk was just a little too short. It was fine after adding a 2 or 3 inch extension (I made a longer adaptor sleeve for the gearknob).
have fun!
the moa 2
posted on 6/1/05 at 12:13 AM Reply With Quote
Wow lots of info there didn't realize this would have been a major issue and that kit car designers haven't yet made chassis that suits the gearbox a bit better.
The guides look very in depth and a nice walk through guide but not being a engineer with engineering skills im not sure im up for the challenge, althought im am certainly gonna take a good look at it.
What are the major issues if there are any on just cutting the lever just above the shaft and below the weird blobby bit which is about a quarter up the stick, and then welding it back on just at an angle. ?
posted on 6/1/05 at 08:15 AM Reply With Quote
Only that your gearshift "H" pattern is going to be nearly vertical, instead of horizontal. Apart from that, loads of people have done it and been happy with the result.
If you're not up to making your own shift extension, have a look at the Westfield one - vaguely the same as mine, but more expensive!
cheers,
DaveFJ
posted on 6/1/05 at 09:42 AM Reply With Quote
Looks like your gonna have to go into production Dave, or perhaps Darren @ GTS could start selling them ? (only with Dave's permission of course)
Dave
posted on 6/1/05 at 09:45 AM Reply With Quote
I had wondered about that...
... means opening up the transmission tunnel and measuring the bits properly (they were "fitted" originally, i.e. adjustments made as work progressed to make things work)
DJ
[Edited on 6/1/05 by David Jenkins]
DarrenW
posted on 6/1/05 at 10:33 AM Reply With Quote
Mac#1Motorsport do an extension for the type 9 box. I think they are about £65 from memory. My chassis is redesigned to fit the gearbox further back so the extension is not needed (probably helps weight distribution as well as engine is further back).
posted on 6/1/05 at 06:40 PM Reply With Quote
check out the for sale section for details of who was thinking of having some made. Rusty
zetec
posted on 6/1/05 at 07:14 PM Reply With Quote
You could always use a MT75 "box. The gear lever is really easy to relocate on that...blah blah blah.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
posted on 6/1/05 at 08:02 PM Reply With Quote
Mount it all 4" further back
Mine's in the right place and it's a Pinto with a type 9 box.
Ian Pearson
posted on 6/1/05 at 10:37 PM Reply With Quote
Ditto.
the moa 2
posted on 8/1/05 at 06:41 PM Reply With Quote
Just had a chance to look at a westfield remote and i can now understand how it works .
£80 odd quid its gonna cost and i think unless i find a second hand one or if someone here is knocking them out i shall get one of them!
One thing i noticed different from westy's one and then one in the guides from d.jenkins and his pal is the way you dont have to drill or alter my type 9 gearbox in any way as oposed to drilling in the plate just above the prop.
Well if anyone does have one for sale please let me know . Original or not !
andyace
posted on 8/1/05 at 07:33 PM Reply With Quote
Pinto with Type 9
I hve a 2.0 pinto with type 9 box, how far do I have to try and set it back to get the gearstick in the correct place?
posted on 8/1/05 at 07:55 PM Reply With Quote
About here.
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=scuttle_off.jpg
andyace
posted on 8/1/05 at 10:47 PM Reply With Quote
Cheers does the position of the gearstick measure easy from any point on the chassis so I can ensure I get it in the correct place?
Also did you make any chassis mods to get the gearbox further back?
Thanks, Andy
<<  1    2  >>
